Company Logo Shop Now
Soaking Cylinders before starting
alberta dave
09-19-2020 09:34:42
I need to move a 770 gas that has been sitting for a few years. Engine was free a couple of years ago but it has sat with the carburetor off since then with a rag stuffed in the bottom of the manifold. I was thinking I better squirt some witches brew into the cylinders before pulling it into the shop to install new carb and fuel tank. What do you experts mix up or is there a ready made product? Last time I tried to soak cylinders I used Marvel mystery oil, gas line anti freeze and some penetrating oil but sadly the old 400 cu in her did not break free so canít say I have ever had a successful treatment.
LandonT
09-21-2020 19:26:32
 Re: Soaking Cylinders before starting in reply to alberta dave, 09-19-2020 09:34:42
There is a product called Engine Fog that can coat the cylinder walls before turning it over...probably more of a preventive measure than something to free up a stuck engine.
gary66
09-20-2020 13:51:22
crank it...I'm sure it will be fine
Olliejunkie
09-19-2020 22:23:28
Good idea to turn it over a few revolutions to make sure the the whole valve train is free.
rustred
09-19-2020 11:28:48
this subject everyone has there opinion and brew. lubing the cyl's on any engine sitting for a long time with exhaust covered as in years should be done, stuck or not. and the cyl's should be lubed when the tractor is first parked ,like about 5 squirts from an oil squirt can. roll engine over and good enough. if tractor has sat out side with open exhaust and rain got in your done. its tear down time. it takes very little condensation to stick the rings to cyl's. and most times they will come loose from lube. and is this engine stuck or free and is pipe covered?
alberta dave
09-19-2020 11:36:18
 Re: Soaking Cylinders before starting in reply to rustred, 09-19-2020 11:28:48
The exhaust has be covered and an oily rag was stuffed into the carb port on the intake manifold so I am hoping that it is still free. I donít want to roll it over until I put something in.
rustred
09-19-2020 18:44:06
 Re: Soaking Cylinders before starting in reply to alberta dave, 09-19-2020 11:36:18
yes that is smart. just remove valve cover and squirt some oil on valve stems and rockers and your good to go. dont need to be removing manifold. also just drain that old oil out and let sit overnight with plug out. then fill with engine oil.
old
09-19-2020 10:06:03
I free up engines using plain and simple ATF. I fill the cylinders and also pour as much down the exhaust as I can till it leaks some place and let it sit a few days. I have done that to 30 plus engines and most freed right up
alberta dave
09-19-2020 11:43:30
 Re: Soaking Cylinders before starting in reply to old, 09-19-2020 10:06:03
I never thought about freeing the valves so maybe I will pop the manifolds off to lubricate the upper parts as well. I have some old small cans of dextron that have been sitting on the shelf since 1990. This sounds like a good way of getting rid of them.
old
09-19-2020 12:45:56
 Re: Soaking Cylinders before starting in reply to alberta dave, 09-19-2020 11:43:30
Being that old be sure you shake them up real god before pouring it in.
Today's Featured Article - Bad Vibes - by Curtis Von Fange. One of the strangest ways to communicate with our tractor is to ask it how it feels. "Ask it how it feels," you say? Yup, ask it how it feels. Now, as with the other articles in this series one has to be able to hear what 'ole blue' is trying to say in response. The nice thing about our old iron friends is that they are usually quite consistent in their response, rather unlike some people I know who might change what they say due to the weather or other mitigating circumstances. But since t ... [Read Article]
Latest Ad: John Deere 855 parts manual. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
