White 2-150 rear end
rrlund
I never gave this much thought before, but what rear end did a White 2-150/MM G1355 use? It's an Oliver isn't it? They had the closed center pump mounted on the side. Was it the same one as a 2255 Oliver? It couldn't have been the same as a 2050/2150, those had the open center pump inside.
Randy: The 2-150 from the clutch back is an Oliver The ring and pinion has a different tooth count than a 2255 because of the different RPM of the Cat and M-M engines but both are planetary final drives.
