88 front crank seal
Chris Ford
New User
I was pulling off the crankshaft pulley to refit with new bolts so that it would not keep loosening up. As Iran bolts through the pulley the bolt run into the oil seal punching a hole timing gear cover. I will be fixing the hole and installing a seal. My question is behind the cover in between a flange on a crankshaft and the cover there's like a two or three piece seal looking for help with this issue? Any thoughts thank you.
I think you're looking for part# 1K126. If you google that number you should get a steiner part # result, #OLS3489. Is that what your seal looks like?
