Company Logo Shop Now
Camshaft
ziffel
07-28-2020 08:46:24
Casting Number on Shaft Is 190223. What can it be used on?
scootergmc
07-28-2020 09:44:30
 Re: Camshaft in reply to ziffel, 07-28-2020 08:46:24
I think the later 283/310 gas and diesel cams all started with a 2 for a casting number. So maybe a fleetline? 88? Just a guess at this point, and I'm probably wrong.
J. Schwiebert
07-28-2020 13:06:25
 Re: Camshaft in reply to scootergmc, 07-28-2020 09:44:30
Measure the lift on the lobes. the 7 main bearing engines have different valve arrangements while a 1650 gas and the 88 engines will be the same.
ziffel
07-28-2020 13:19:47
 Re: Camshaft in reply to J. Schwiebert, 07-28-2020 13:06:25
After some cleaning I found an upper case "D" stamped between the lobes that operate the valves for the # 4 cylinder.
ziffel
07-28-2020 10:26:21
I think you are correct. We think it came from a 88/S88. Does it matter if it is gas or diesel? More importantly can it be used in 1655 gas? Thanks
Copyright © 1997-2020 Yesterday's Tractor Co.
