Oliver 1600
wallyh57
New User
One of my remotes on my Oliver 1600 drips oil when the tractor is running. Can I replace part of the remote to fix this leak or is there an o-ring or something that needs to be replaced?
Thanks
Wally
Is the remote coupler itself leaking then? One of those will always have a little pressure on it when it's running. That said, it
shouldn't leak. I put a brand new pair of Pioneers on my 1600 and they leaked from day one. I took two male pioneer tips, put pipe
plugs in them and plugged them in. It doesn't leak a drop as long as they're plugged in.
Do like rrlund suggests. The pioneers male ends with 3/4” NPT plugs will keeps your remote ends clean and are far less likely leak. I keep a set for hay
season when I drop my loader off and only use 1 remote for the baler and haybine.
