Company Logo Shop Now
Re: Fiat built tractor brakes
Mitch Poindexter
07-19-2020 19:30:27
The differential supports are bolted on to the rear housing and locked with metal tabs. The supports hold the bearing race for the differential bearings as well as the oil seals that the axles go through. You will be able to see them once you have pulled the final drives out of the rear end. There are factory shims between supports and the housing which are used to provide proper pre-load on the differential bearings.
rrman61
07-19-2020 19:33:14
 Re: Fiat built tractor brakes in reply to Mitch Poindexter, 07-19-2020 19:30:27
Ok thanks again
Copyright © 1997-2020 Yesterday's Tractor Co.
