Company Logo Shop Now
Oliver 1250A head problems
Flat
07-15-2020 11:35:01
the head gasket has leaked in the same spot 3 times now. parts are hard to find for this model. The mechanic I had didn't think that the head was compromised.
I now feel that I should remove the head and have it inspected and shaved. there are 2 different head gaskets for this model, I am told. knowing which one I think could be troublesome for me. also, getting the right head bolts new may be a trick.
I live in sw washington, not the best country to find oliver advice or help.
Any comments, pointers or advice of any kind would be appreciated.
Flat
Ken Loewenhagen
07-16-2020 04:36:48
 Re: Oliver 1250A head problems in reply to Flat, 07-15-2020 11:35:01
You said the mechanic didn't think the head was compromised. Didn't think might be the problem. Take it to a machine shop and have them check it. If it checks out ok then, I suggest you do some checking of the block. I had that happen with an Oliver 70. Block and head went to a machine shop. Milled the head but, he said the block was good. I don't think he checked the block. Put it together and started adding water and had seepage before the radiator was even full. Pulled the head and put a straight edge across the block. Found an .008" gap. Complete tear down of the engine and had the block milled. It's been good since.
Flat
07-15-2020 21:06:25
I'm new to this website and can't find your email or how to add mine
dvmustang2@gmail.com
360-837-3986
I think we were thing it was bad head bolts. he checked it with a straight edge. I believe that I need to have it checked better. It ran strong even though it would blow some pretty black smoke at load. as soon as it leaked again, I shut it down.
J. Schwiebert
07-17-2020 17:42:23
 Re: Oliver 1250A head problems in reply to Flat, 07-15-2020 21:06:25
I will work on that tomorrow. I am going to my grandson's graduation first.
Traditional Farmer
07-15-2020 22:58:01
Did you check the top of the block?
scootergmc
07-15-2020 16:50:39
He has good history on your tractor too:
http://www.importtractorparts.net/olivertractors.html
J. Schwiebert
07-15-2020 16:06:26
You said it fails the same place. Where is this place. What have you done to find the problem> send me an e-mail.
Flat
07-15-2020 15:33:37
I don't think so. I will tomorrow when they open
thank you
J. Schwiebert
07-15-2020 18:51:21
 Re: Oliver 1250A head problems in reply to Flat, 07-15-2020 15:33:37
If you have had 3 identical failures just changing the gasket will not solve the problem!. Send me an e-mail and include your phone number. J.
scootergmc
07-15-2020 15:02:47
Have you ever talked to these guys? I'd give them a shot: http://www.importtractorparts.net/
Flat
07-15-2020 15:00:10
I forgot to mention it was diesel and 1968 2wd
so, where do I get the head gasket set with the new head bolts. maybe even head, if I find it is cracked?
The last time we tried this was years ago and we had a very hard time chasing anyone that knew anything about it. My mechanic was not very motivated, he is more of a parts changer. he just not very through and is out of that work now (health).
I have an old manual that is complete top to bottom on this tractor, he also got one out of it.
Flat
07-15-2020 14:43:28
Traditional Farmer
07-15-2020 13:11:53
If its a 1250-A it'll have the 3 cylinder diesel, parts shouldn't be any problem to find or a used head.
Copyright © 1997-2020 Yesterday's Tractor Co.
