Company Logo Shop Now
1650 diesel with the stutters
mnoliverguy
07-12-2020 20:29:49
Seems to stutter when going up a hill or when hauling a bale. Have changed filters fuel is clean fuel lines are clean don't seem to have any fuel leaks, Any Ideas?
scootergmc
07-13-2020 09:20:29
 Re: 1650 diesel with the stutters in reply to mnoliverguy, 07-12-2020 20:29:49
Also, I'd be popping off the injectors and checking the pressures.
So how long since the pump was rebuilt? Are you using diesel fuel treatment? These pumps don't like the non-lubricity of ULSD. Return line check valve? I'm just throwing things out there at this point, but it definitely sounds like a delivery problem.
scootergmc
07-13-2020 09:16:13
Check with Dieseltech. Guys around here have been happy with his price and service.
scootergmc
07-13-2020 07:16:45
Is the pump still original? What's its history?
scootergmc
07-13-2020 07:15:44
Did you pull the cover and see any coffee grounds?
mnoliverguy
07-13-2020 07:40:55
 Re: 1650 diesel with the stutters in reply to scootergmc, 07-13-2020 07:15:44
no grounds pump was rebuilt when i bought tractor seems to run fine otherwise. what does it cost to redo pump?
Dieseltech
07-13-2020 03:18:21
Times two what scootergmc said, probably injection pump repair time. Whenever you have engine speed changes for no reason with good fuel flow to the pump it's a sign internal governor needs repair. Keep running it, and soon the weight retainer pins will shear off, seize the rotor and break the drive shaft..
mnoliverguy
07-13-2020 07:03:37
 Re: 1650 diesel with the stutters in reply to Dieseltech, 07-13-2020 03:18:21
I tried the loose cover the last time and it did not make a difference. I knew I had asked b4 but could not find it. so tried again thanks any other Ideas?
scootergmc
07-12-2020 20:47:28
Yes, here's some ideas from your old thread in April:
https://forums.yesterdaystractors.com/viewtopic.php?t=1428761
It could be time to go through your pump.
Copyright © 1997-2020 Yesterday's Tractor Co.
