super 55 transmission and hyd oil need changing
deene
are there seperate resevoirs or is it all together, there are 3 drain plugs under this tractor, 2 socket style under the transmission and one pipe plug under the rearend, thanks for any replies, have a great day
The hydraulic is separate from the rear end and transmission. You pump the hydraulic oilout. The 3 plugs do the transmission and final drive.
