Oliver 770 PTO rebuild/parts
r8f1k
I have a nice Oliver 770 PTO that needs a good overhaul, resealing. I am looking for the following:
1) Bottom PTO pan gasket
2) The gasket that goes behind the clutches (about 3" round, 3 holes around the perimeter) mounts directly to the main housing
3) The rear cap/plug that sits behind the very end of the output shaft. It has worn through the metal and I would like to find a new one.
gaskets could be made easily enough, I likely have a plug but I would only look for one if you were unsuccessful at buying a new one.
My go to place for new Oliver is Maibach tractor in Creston Ohio.
Have you had the output shaft out of your gear case? There was a change made in how the shaft was held in there and since your plug is worn through you will need the new style kit and maybe a shaft too.
I just bought the PTO yesterday. I know nothing of its' history. Any thoughts on another supplier other than Maibach? No problem with them, just in case they don't have it.
Korves Oliver in Waterloo, Illinois. They carry most 'seals and o-rings' per their sales bill. Find them on the web.
