First, what is the last three digits in both tractor serial numbers?  If the numbers are the same they are identical, and all parts will exchange.
   There is three series of transmission/finals in the model 1850.   The early 1850 and all 1750 tractors are the same.
don't know part tractor serial. the gear overall width is the same . but the 1750 the teeth are cut down , for a narrower gear width . leaving a step to make it the same width at the shaft
