one piece wrist pin bushings
I'm rebuilding my 1655 diesel for the second time. The first time I replaced the wrist pin bushings. Can these be reused or should I replace them again? By the way, the problem this time was a spun rod bearing. No evidence of problem with the one piece bushings.
we are not there or have rod in hand so impossible to say. if your not sure have an experienced guy check them. any play whats so ever and they must be replaced.
Well you are getting a different set of sleeves & pistons so the pins will be different. Clearance is measured in tehth of a thousand. New bushings and have the rods reconditioned too and have them bored to length!.
