Company Logo Shop Now
TractorLinks.com
Valve clearance for a 310 Waukesha
MikeO-WI
06-24-2020 08:13:04
I thought I would ask what should be the correct intake and exhaust valve adjustment for the tappets. My mechanic said I shouldn't have to adjust it if I kept the rack intact and attached to the head as he took it off. We had a bad head gasket and I disagreed with him. The rack had to be removed so it could be properly torqued. I also know that the various secondary publications can be incorrect or not up to date. This is not the engine block with the built in oil cooler but it is a turbo'd diesel on an Oliver 1855. Thanks, just trying to do it right.
oldwrencher
06-25-2020 16:30:08
 Re: Valve clearance for a 310 Waukesha in reply to MikeO-WI, 06-24-2020 08:13:04
when I worked for a massey/former Oliver dealer we were told valve settings for all waukesha engines should be .022 intake and exhaust.I use that without problems, I think manuals said .020 and .030.Your choice I guess
rustred
06-24-2020 17:47:12
you are totally correct!, and so why does the mechanic say that? any time the head is off valve set happens,.. and on a retorque valve set happens again. when you squeeze head gasket you are decreasing the valve clearance. i dont have the clearance, but if you want to show him torque the head and then take the valve measurements , that will prove him wrong.
scootergmc
06-24-2020 09:08:26
This is off the top of my head, but .030 for both is what I recall.
Copyright © 1997-2020 Yesterday's Tractor Co.
