I want to take the motor out of my 880 to repaint and fix some oil leaks on it. My question is do you take the PTO shaft and clutch assembly out to
remove the motor or in the picture do you unbolt the coupling clamp move it forward and then remove the motor without taking the PTO shaft out. I've
been told both ways just want y'all input before i start. Thanks for the help
