Good morning,
I recently made another post about the Hydraulic pump idler gear etc here... https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=oliver&th=226932
However.. I wanted to make a separate post about fluid specifications and capacities.
The info I have so far is.
Cockshutt/Oliver 1550 (1966 year?)
-Gasoline motor
-Model number :355-21137
-Serial number: 201 861-504
-Hydra-drive 2 speed transmission
-hydro-electric 3pt
I do not believe it has depth stop cylinder system.
Can someone help me with these specs and capacities for the following items. Please correct me if I am wrong. Or more if I am missing some!
*Engine oil w/filter-
5.75 quarts (SAE 10w)
*Hydra-drive fluid-
6 quarts, Type-A/Dextron 3 equivalent?
*Hydraulic Fluid-
26 quarts,Type-A/Dextron 3 equivalent?
-Power steering,PTO, lift system all share this fluid?
*Transmission/final drive/diff-
40 quarts
80/90w gear oil.
*Engine coolant-
I see it just says 5 gallons.
Does this use typical automotive green coolant?
Please correct me if I'm wrong.. Also if you have a picture of the fill/check points for each of the fluid reservoirs.. That would be awesome!
Thank you!
Shawn
-Gasoline motor
-hydro-electric 3pt
*Hydra-drive fluid-
*Hydraulic Fluid-
40 quarts
80/90w gear oil.
*Engine coolant-
Thank you!
Shawn
