Cockshutt 500 series oil drain plugs
550Doug
Location
Southern Ontario
Will an oil drain plug for a 540 also fit any other 500 series tractor? I think they may have different part numbers but they could be the same size. The 540 size is 7/8 -18, I think.
Thanks
(quoted from post at 08:17:29 05/23/20)
550Doug,
I am 98% sure that the same oil pan plug will work on both the 540 and 550 COCKSHUTT built COCKSHUTT Tractors.
Phil Heisey
215-256-8651
If that is the case then the 570 (6 cyl version of the 550 Hercules motorI is likely the same as the 550 and the 540. So what about the 560?
