Cockshutt 20 3 point
jimvw
Have a Cockshutt 20 with a 3 point problem. Settles immediately when returning the lever to neutral. Have about every Cockshutt book but for a 20. Anyone have a theory of operation or a service and adjust procedure for the hitch? is it normal on this hitch that it raises when you push the lever ahead and lowers when you pull it back. Seems opposite of most. Thanks
Yes, the control lever is working properly. Yes, it is opposite most other tractor brands.
Your problem is either in the cylinder or the valve. Both of these are inside the (under the seat) tin top cover with the 4 acorn nuts. Repair is usually easy and most parts are economical.
We have all the manuals and parts on stock here for all COCKSHUTT BUILT, COCKSHUTT/CO-OP Tractors.
Phil Heisey
215-256-8651
