Hi guys does anyone have a cure for PTO free spinning on the 1655's when the PTO lever is in the off position? I've tried all the adjustments I could find in the manual and the PTO still spins, sometimes it will stop when idling around 1,200 RPM's but not always. As long as the implement has enough drag it will stop but say an empty manure spreader will continue to slowly operate unless the PTO handle is held back hard. Once the first bucket of material is dumped in it has enough resistance and stops. I would like to bale with this tractor but I would like to have the PTO actually stop and stay stopped so the tractor can stay running while working on the baler. Thank you for any advice!
