Company Logo Shop Now
TractorLinks.com
Popping out of gear
Oliver18001850
05-17-2020 18:55:53
I have an 1850. That pops out of gear going downhill. What needs to be replaced that is causing the issue
J. Schwiebert
05-19-2020 05:48:48
 Re: Popping out of gear in reply to Oliver18001850, 05-17-2020 18:55:53
How about more details as to what gears it pops out of and a tractor serial number as well. It could also be in the top shaft too.
Hay maker2
05-18-2020 14:02:03
gary66
05-19-2020 14:52:40
 Re: Popping out of gear in reply to Hay maker2, 05-18-2020 14:02:03
good post haymaker.
Hay maker2
05-18-2020 09:58:39
Bevel pinion shaft is loose which allows the shaft to get pulled towards the rear when you go down hill and at that point it jumps out of gear.
Then again it could be the intentionally engineered freewheeling of the Hydra-Power not being in directed drive too.
big tee
05-18-2020 05:31:25
Around here they used to call that "Arkansas Overdrive"---Tee
Copyright © 1997-2020 Yesterday's Tractor Co.
