Oliver 770 engine removal
So I have never pulled the engine out of one with a Power booster. On the others I just remove the master link in the chain coupler and lift engine straight up. How does it work with the shaft in the power booster? I have the pto out. Thanks!
You need to split the power booster over center clutch. Send me an e-mail and I will give you some pointers. I started with Oliver on the Power Booster program in 1960, My how time flys, J,
(quoted from post at 07:18:10 03/31/20) You need to split the power booster over center clutch. Send me an e-mail and I will give you some pointers. I started with Oliver on the Power Booster program in 1960, My how time flys, J,
Thanks J! I have an 880 and I would like to get the PB to work in it sometime. The one in this 770 has not worked for years the owner says. My email is [email protected] I will look for the serial number on the 880.
