Company Logo Shop Now
TractorLinks.com
Re: hydraulic help, a little long
JD Seller
03-29-2020 08:20:10
Mike The closed center plug should just have a longer section with an oring the seals the return passage so the oil does not free flow when the valve is in neutral. You can just cut it off so the internal port is not sealed. As for the return you can easily just hook the return to where you wanting too. The only issue would be IF you used the remotes or three point at the SAME time as the loader valve there would be pressure on the return side of the loader valve. This could make it not function as both sides of the valve/cylinder would have pressure on them. This would ONLY be true while the oil flow was going to the remotes or three point.
I have seen several loader on Oliver tractors hook up this way and they were used that way for years.
Mike(NEOhio)
03-29-2020 13:33:41
 Re: hydraulic help, a little long in reply to JD Seller, 03-29-2020 08:20:10
The reason I asked is that in a reply to an earlier post in the JD forum someone stated that not all valves are rated for full system pressure at the return port. What I want to do is use the open center plug (or cutoff CC plug) in the BYD port making the OUT port supply the power beyond With the closed center plug out, the OUT and BYD ports are interconnected. The valve body casting is the same thickness around the IN and OUT ports so I don't think that will be an issue.
J. Schwiebert
03-29-2020 16:29:43
 Re: hydraulic help, a little long in reply to Mike(NEOhio), 03-29-2020 13:33:41
Mike send me an e-mail
Mike(NEOhio)
03-30-2020 10:14:21
 Re: hydraulic help, a little long in reply to J. Schwiebert, 03-29-2020 16:29:43
Sent last evening.
Copyright © 1997-2020 Yesterday's Tractor Co.
