oliver superior
caterpillar guy
I've got a couple NOS disks for the seed opener and a couple of the steel side plates that go down beside the seed disc. The piece that the spring lift bar fastened to. There are I think we counted 3 new disc and maybe one used one and 2 of the side pieces. This was the superior drill with rubber tires and wood boxes with seeder for grass/hay. Will post pictures here later today. They are in Shiawassee county MI. Calling will be best 989 413 5684.
If you can come up with 5 of those discs,I'm interested for sure. I need them for my 64 drill. I talked to a guy over in the thumb yesterday who said he had some good used ones. He was going to check this weekend,didn't know what he wanted for them,but shipping was going to be the big expense. I'd consider driving over to get yours. Can't buy you lunch at Cracker Barrel like I did Claud because of the lockdown. LOL
I'll wait for you to post the pictures.
Pictures of the disk's
Shoot,I was just going to get your number and call you. I hoped they'd have the bearings and caps too. I just got another bearing loosened up and put it in the one good blade that I have left,but the other 4 are pretty much toast,bearings and blades. That looks like a bigger center hole and wider pattern for the holes than mine are.
Let me see what that other guy comes up with this weekend.
These are a concave disc, not flat like a corn planter disc. There is an old drill down back that may have the parts you are looking for on steel wheels. Would be available also. Been a long time since I looked at it. Would be a full drill of parts. Those would also have the concave disc's on them.
Mine are concave too. I didn't think about needing any of these when Claud was getting me that sprocket. I ground the rivets off on one. The center hole is a hair under an inch and a half and the rivet holes all the way across is two and three quarters. I had one brand new blade and bearing that came with it,it measured about 13 and 3/4 diameter. Most of the old ones on it are worn down closer to 13.
The bolts are 5/8ths,use a 15/16ths wrench. If you think you've got some on an old drill,I'd come over and take them off so you don't have to. I'll email you my number.
Walked back and looked at mine, not much left they settled in the dirt and the bottom half pretty much rusted off and the bearings are rusted solid.
Thanks for checking. Like I told Mark,there's a guy over east who says he has some. He works road construction,said he was going home this weekend and would try to find some good ones. Said he had a couple of them parted out.
