Company Logo Shop Now
TractorLinks.com
550 Update
super99
03-23-2020 15:25:49
Making some progress, Timing cover is on, governor housing is on, oil pump and distributor is in, pan is on. Trying to decide whether to put the head on and then lift it off of the motor stand or carry it to the tractor with the head off and put head on after motor is installed. It'll probably set for a few days, Tuesday is trash day and the bottom of my dumpster needs replaced. I have a new one, so I should fix that before finishing the 550. Chris
Super 55
03-27-2020 18:17:20
 Re: 550 Update in reply to super99, 03-23-2020 15:25:49
Super99, I had someone rebuild my engine in my Super 55 and I recall they mentioned there was a head bolt that has an oil passage. It has to be in the correct position on the head. Wish I was more knowledgable on the matter, but just wanted to warn you so that you put it in the right place. It may be something that is totally obvious, and I hope it is. Just didn't want you bolting the head on and then having to change it. I am sure someone will let me know if I am full of beans.
RCP
03-23-2020 19:49:25
Did you get the oil pump installed correctly? It drives the distributor, if the pump is not in correctly it will throw the location of #1 out of position.
Rich
tom upton
03-23-2020 16:58:17
Just curious what did you end up putting on end of crank pulley?
super99
03-23-2020 17:43:59
 Re: 550 Update in reply to tom upton, 03-23-2020 16:58:17
The dealer had a fiber washer with a key slot in it for $2.00. I put it on and he said to leave the big fiber washer off, it would just mess up the seal.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
