Pulled off cab 2-105
That's a job I hope I never have to do. If I have a reason to,mine might be sitting in the corner of the toolshed for a while. Did you get that pinion seal changed or were you waiting until you got the cab off?
Let's see if this link works for your video.
Direct link
No I?m going to do it once I have the cab off only if it?s leaking however my big question is what I need to do to change the brake housing saying last time I did my brakes they were quite thin I have not talk to one person yet that actually put a new brake housing on but I?m just going based on what Bruce Hofferbert had told me years ago but he also said you had to pull the cab to do the seal and several other people of told me they change the seal without ever taken a cab off. I wanted to see if anything was leaking underneath the cab since there was so much grease and oil there but my inclination right now is the leak is coming from the orbital steering motor
