The governor weight pins are knurled on one side and have a c-clip on the other side. The holes in the weight carrier that the knurled pins are pressed into are worn to the point that the the pin is no longer a press fit.
This seems to be a problem with these governors. The pins become loose, fly out, and then the governor is damaged. I've been told the weigh carrier is no longer available. I do have a used carrier but the pin holes are a little loose. These are pictures of the bad one that came apart.
Has anyone spot welded the pins to the carrier to keep them in place? Any other ideas?
