Company Logo Shop Now
TractorLinks.com
More 550 pto
super99
02-25-2020 15:17:48
I heated the screw on the pto and got it out ok. You all were right, there are 2 set screws in it. Now on to getting the hub off of the shaft. Pretty obvious someone was in there with a punch and chisel banging on the nut. Any suggestions on how to hold the hub while trying to get the nut loose? Thanks, Chris
spmn
02-26-2020 06:40:08
 Re: More 550 pto in reply to super99, 02-25-2020 15:17:48
I use a 1/8th drill bit & drill the staked places out by laying the bit in the splines---It is a right hand threaded nut---You can make a spanner wrench using a pipe & some square key stock---Hold the shaft at the rear end with a pipe wrench or a pto shaft---HTH
KLPinNC
02-25-2020 18:42:06
Nut is staked at the grooves, use a small punch to unstake the nut. I made a spanner wrench with a piece of pipe.
J. Schwiebert
02-25-2020 16:43:14
One of those spanner nuts is also left hand. Chris it has been 45+ years since I worked on one of those PTO's. I will also be out of town Wednesday. Do you have a book?
super99
02-25-2020 18:22:47
 Re: More 550 pto in reply to J. Schwiebert, 02-25-2020 16:43:14
I have an I&T manual.
B A Star
02-25-2020 22:43:46
 Re: More 550 pto in reply to super99, 02-25-2020 18:22:47
   Just a word of advice: Go to the rear of the tractor and look at the position of the oil level plug and note how far it is off the floor.   In the opening where you are at there is a couple of seals, however there is only one that is below the oil level.   It is inside the driven gear and seals between the gear and long PTO shaft going to the back of the tractor.
   A lot of guys have overlooked this seal and complained that it still leaks.   I have looked at too many tractors, answer: DUH didn't see that seal!
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
