Company Logo Shop Now
TractorLinks.com
D298 White Hercules engine will it fit in an Oliver OC?
vermonster90
02-25-2020 11:41:08
Will a D298 fit in OC46? I just purchased a GOV remanufactured D298ER wondering if anyone has experience retrofitting a Oliver tractor? Heard they work for Cockshutt's 570.
vermonster90
02-26-2020 09:59:48
 Re: D298 White Hercules engine will it fit in an Oliver OC? in reply to vermonster90, 02-25-2020 11:41:08
I was actually thinking along those lines, I have an OC 46 which has problems. I got such great deal on this engine it might almost be better to just get Cockshutt and sell the Oliver.
vermonster90
02-25-2020 21:33:52
Yes it's definitely a government engine I bought it from government auction. It was remanufactured still in it's sealed crate. I took a shot at it and won. Was thinking it might fit. But looks like in general this thing is to big to fit. Going to do some measuring tomorrow to double check. I couldn't pass it up a complete reman a engine, impulse buy. I may try find the 4 cylinder D198. My current ibx needs a ton of work, choking amounts of blow buy, not much power and compression readings from 40 to 90, all with a couple of stripped head bolts. What tractor does the D298 for in?
ArleninOr
02-26-2020 10:23:42
 Re: D298 White Hercules engine will it fit in an Oliver OC? in reply to vermonster90, 02-25-2020 21:33:52
There is a 198 on the Portland, Oregon farm and garden site.
P Heisey Harleysville,PA
02-26-2020 06:05:15
Compared to the Cockshutt 570 DD298 engine,the Hercules 298 military engine has a much heavier crankshaft, can clockwise or counterclockwise and the fuel injection pump may be on the opposite side of the engine and will be a different brand of pump.
Phil Heisey
Traditional Farmer
02-26-2020 03:50:47
298 came in the Cockshutt 570,I'd be looking for a 570 to put it in or not much trouble to put one in a 40 or 50 Cockshutt.
J. Schwiebert
02-25-2020 16:45:55
That ER on the end of that 298 means that it is a Military engine and some of the major internal parts are different!
90 Percent Retired
02-25-2020 12:48:16
Quoting Removed, click Modern View to see The Cockshutt 570 used a 6 cyl. 298 cu. in. Hercules engine. The Cletrac OC 46 used a 3 cyl. 130 cu. in engine. I'm sure the drive line would not last at over 3 times the torque. The 6 cyl, would also be nearly twice the length.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
