88 hydraulic filter and fuel filter
Nick167
Could someone give me a part number for the hydraulic filter on my Oliver 88 diesel also if you have the fuel filter number that d be great thank you!
If you go to wixfilters dot com,there's a chart that'll give you all the filter numbers for that tractor. Might be quicker to go there and find them than to wait for the right person to see the post. I looked up the numbers for all the filters on all the tractors I have and wrote them down on the inside of a cabinet door in the shop.
(quoted from post at 15:47:08 02/11/20) If you go to wixfilters dot com,there's a chart that'll give you all the filter numbers for that tractor. Might be quicker to go there and find them than to wait for the right person to see the post. I looked up the numbers for all the filters on all the tractors I have and wrote them down on the inside of a cabinet door in the shop.
Thanks I didn t know that had that that what I ll do
I didn't realize that mine just has the element type right before the injection pump. Wouldn't have to have the numbers would you? I tried checking wix's website but didn't have any luck
Search
Off highway equipment,Oliver,Construction and farm tractor,then 88. This link should get you right there. Lists two different fuel filters,two different oil filters.
Link
I was able to get it this time although they only list a fuel and motor oil filter no hydraulic filter number but I?ll try Agco website see if I have any luck thanks for the help!
The hydraulic filter should be part # 1LA5351. That should cross reference to a lot of different manufacturers.
