Three Oliver Issues.
1. Oliver 77, I had to take the top off the transmission and am having trouble getting the gears lined up to correctly align. I seem to get the low range to line up but when I put the top on I have no hi range. It worked perfectly until I got a hold of it.....Any books or information you can recommend?
2. I need a new PTO Shaft assembly for the same tractor, any parts sources?
3. And last.....I have an Oliver 62W Wire tie baler and am needing a few parts, mostly for the wire twist mechanism.
Are there any parts sources that you can steer me to? Do the later model Oliver Wire Tie balers use the same parts as the 62W?
Thanks in advance.
Thanks in advance.
