Company Logo Shop Now
TractorLinks.com
Re: 1850 Oil Pressure and other questions
alberta dave
01-15-2020 12:51:24
The Perkins in the 1850 has the single bolt at the front to support the engine. Did the engine from the white combine have the same configuration? I can still find the occasional White or Massey 510 combine up here that have the Perkins engines in them. I passed on a couple last year because the combines were in such good shape I just could not imagine scrapping them just to use the engine. They went cheap enough. I would consider doing this if I could get one home for less than the cost of a rebuild.
rrlund
01-19-2020 06:53:44
 Re: 1850 Oil Pressure and other questions in reply to alberta dave, 01-15-2020 12:51:24
A 510 engine will work. It doesn't matter which combine you get one out of,Super99 used one out of a 750. You have to strip the combine engine down to the block and head for the most part. You use the parts off the tractor engine to remake it to fit. The oil filter and cooler base has to be moved to the other side and the plumbing for the oil pump had to be changed to take the oil to the other side. You put a pipe plug and soft plug in where you take the combine filter base off. You use the tractor front engine cover,oil pan,water pump,front pulley,tappet cover,rear side cover,even the injector lines since the combine uses a cable and the tractor uses a rod. The combine lines aren't bent and spaced right for the rod to run down through them. The plate on the side of the injector pump has to be changed to hook the rod to vs the one for the cable.
Don't over think it,it's not a huge deal,you just have to swap things over until the combine engine looks like the tractor engine. I just don't know if it's worth the cost of overhauling a 354. You can buy a low hour combine engine for way less than it costs to overhaul one. Even better if you can buy the whole combine and sell it for scrap after you take the engine out.
alberta dave
01-21-2020 05:47:41
 Re: 1850 Oil Pressure and other questions in reply to rrlund, 01-19-2020 06:53:44
I am keeping my eyes open for a 510 or Old White combine now. I think I will still rebuild the engine that I have had sitting on my shop floor as the head only has a few hours on it. It really needs to get out of the way. I have a hydraulic pump to change out this week and then its on to the engine.
alberta dave
01-20-2020 21:37:31
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
