588 loader parts
JPERT
I have been trying to locate parts for the hydraulic cylinders for a 588 loader. Some parts are available thru AGCO Parts but many are discontinued. I have been to every hydraulic store in town with no results. I am in need of the 196 631-A bearing nut and 196 630-A bearing. Does anyone have any suggestions?
Did you have the AGCO dealer do a dealer search for new old stock? I needed a seal kit for a lift cylinder on my 7300 Oliver combine a few years ago. The dealer did a search and came up with a whole bunch of them. He found one dealer who had a dozen of them on the shelf. After half a dozen,he stopped reading off dealer names and phone numbers to me.
The 196631A subs to 1881534M1 which is discounted. Looks easy enough part to make for a machine shop or a hydraulic cylinder shop. Still looking for the other part.
It does look to be easy enough to build but estimates were in the $300 to $350 range. I don't think a dealer search was done. I will check on that. Thanks for the tips.
Just an update. I have not been able to find a replacement for the cylinder bearing nuts but, we were able to weld repair the damaged portion of the bearing so they could be re-machined to retain the lip seal. The piston o-rings and back-up rings I was able to get Cat replacements using the Cat dealers "One Safe Source" catalog. I also found replacement seals for my ALCO hydraulic control valve from www.herculesus.com a hydraulic system supply source. I am almost ready to reassemble and install the 588 loader to my 550 tractor.
