Ol 88 trans gears/r and p
88-1175
Do all the 88 trans have the same tooth count on the gears,anyone know the tooth count on all the ring and pinion combos ??
don't have the serial plate..was looking for different ground speeds.are all gear teeth in each gear the same,ex,do all 2nd gears have 20 teeth on the cluster and the corresponding lower gear have 40 teeth ?,or do some have 25 on the cluster and 35 on the lower gear
There are 5 different ring and pinion combinations that were offered in 88's/super 88's: 9/51, 10/47, 11/48, 12/47, & 13/48. The 9/51 is the slowest to 13/48 being the fastest. The row crops had slower ratios and the utility models had faster ratios, they will all interchange though.
