Trying to get my White running again. Sent injector pump to Diesel Care in Memphis, installed and set timing to tdc, as the tag is gone from
fly wheel and only have some tiny marks to use. (double checked tdc with valve cover removed). After bleedings only fires on 2,4,5 white
smoke puffing from 1,3,6. Ran fine except had return line removed to make run before sending off injector pump.
White 2 63-15 back hoe
I have been banging my head adjusting timing, checking fuel flow, etc...
