Part Time Pete
- Location
- Leatherstocking Region NY
I got a chance to put our 1365 on the bush hog and work it a little, and discovered a couple issues
One is the power steering - the fluid level is good, but it's a bear to steer. I've got a manual ordered so I'll see if that helps at all.
The other issue is a bit or a head scratcher - driving on the flat or a side hill to the right is ok, but I you drive with left wheel on the downhill side, the differential lock engages. The first time it happened, I went to make my turn at the end of the field and almost ended up in the hedgerow
Thanks
Pete
Thanks
Pete
