Cockshutt 1800 - aftermarket clutch pressure plate options?
Good day,
Looking on behalf of a friend for his Cockshutt 1800, what are the sources(vendors) for a pressure plate?
I noticed All States Ag Parts came up on a quick Google search but wondering about others.....
TIA
Some of us here deal with Clutch Dynamics in Lansing Michigan. They can get or build you most anything you want.
O. K. Is this an A B or C series tractor? Does it have a 12 or 13 inch clutch? There are also button clutch replacements. Where are you located?
Thanks for the responses.
Not sure of the series of tractor but do know that the clutch is a 12" & to clarify, it's the pressure plate that he needs, not the disc. Would likely prefer
Located in S.W. Saskatchewan(just north of Havre, MT)
Does he need the whole unit (his is missing) or just need his rebuilt? If the latter, google Commercial Brake in Tacoma, WA- they can rebuild anything.
Thanks for the info.
One of the release fingers is broken. Speaking with him yesterday he said he's going to try repairing/welding it. He doesn't want to spend much $$$ on the tractor plus the clutch is easy to R & R so he doesn't have much to lose if the repair job doesn't hold.
(quoted from post at 09:17:47 10/05/19) Does he need the whole unit (his is missing) or just need his rebuilt? If the latter, google Commercial Brake in Tacoma, WA- they can rebuild anything.
A good clutch rebuilder should have those release levers in stock. Better replace all 4and not weld as the other 3 will be worn on the end!
