Cockshutt 570
Robbear
New User
Have a 1958 cockshutt 570 gas 298 Hercules
Have water in the hydraulics
How do I get it out
Cannot find a drain plug and the tank and filter are under the seat
Can anyone help
(quoted from post at 19:54:34 08/24/19) The drain plug is in the back, by the ports for the hydraulic hoses.
Thanks just to add wondering how to get the oil & water out of the pump
Drain the oil, replace with new, unhook
the pressure line that comes off the pump
from the valve or wherever it goes, stick
it in a bucket, pull the coil wire off,
and roll it over. It'll push the old oil
through and out the line. When you see
clean oil coming out, stop, put the line
back on, top off the oil, and put the
coil wire back on.
(quoted from post at 19:18:16 08/25/19) Drain the oil, replace with new, unhook
coil wire back on.
Thanks a lot will try it when it stops raining here in Manitoba
