Company Logo Shop Now
TractorLinks.com
Oliver 28-44 ....extra parts
banjoman09
08-12-2019 20:35:43
When I purchased this tractor this tank was with some extra parts that came with it; what is this and should I put it on the tractor? Thanks.
90 Percent Retired
08-13-2019 11:06:09
 Re: Oliver 28-44 ....extra parts in reply to banjoman09, 08-12-2019 20:35:43
[quote="CVPost-KL in Wi"](reply to post at 07:18:00 08/13/19)
Looks like that is the tank for gas used to start the tractor when they used other fuels to run the tractor after it was warmed up to
KL in Wi is correct, engine was started on gasoline then after warm up on gasoline, shut gasoline off and turn on main tank with kerosene. Before shutting ignition off turn off tank w/kerosene and let engine run till engine dies, (carb. empty). Cold manifold won't vaporize kerosene or distillate fuel, Dad found out the hard way, that's the way I know. From then on only gasoline was used in our tractors.
banjoman09
08-13-2019 13:52:01
 Re: Oliver 28-44 ....extra parts in reply to 90 Percent Retired, 08-13-2019 11:06:09
Thank you guys...I was thinking this maybe...I might try to find where it mounted and put it on even tho I wont use it. Anyone have a pic of this tractor original seat and stand it sits on? I dont think mine is! Thanks!
KL in Wi
08-13-2019 04:18:00
Looks like that is the tank for gas used to start the tractor when they used other fuels to run the tractor after it was warmed up to operating temp.
oliver90owner
08-13-2019 14:24:37
 Re: Oliver 28-44 ....extra parts in reply to KL in Wi, 08-13-2019 04:18:00
Correct, but also needs the kd manifold to tun efficiently - otherwise not enough heat to properly vaporise the heavy fuel.
If it is a gasoline-only engine, the compression ratio may well be too high to run well on kerosene. Could be OK on a modern fuel mix, to emulate. kero.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
