I was wrong about the location of where the oil leak on my 1850 is comming from. It appears to be leaking out of the crack. I have a good farm mechanic that can weld up the crack and fix it right but I will need to remove the oil pan to get it to where he can do it.
My plan is to epoxy it and see if it will atleast slow the leak down until sometime this fall when I can get it in a shop to work on it. Just looking at the tractor it appears I will have to pull the engine out of the tractor to remove the pan. Is this true? Would it be possible to do it without pulling the engine out?
