I hope you can help me. I have an Oliver 770 tractor gas engine. The water pump leaks like a sieve and needs replacement.
Working with a local ag dealer, I purchased a new water pump that otherwise fits, however, after removing the old pump from the tractor, I realized the old pump has a casting with the pulley and fan mount flange as a single piece. The new pump had a plain flange to mount the fan blade but no pulley. All the Oliver pumps I could find also have a plain flange and require a separate pulley. I returned the new pump to the ag dealer who help me with a pulley and took the pump back. At this point, I can either repurchase the water pump and try to source the proper pulley, or try to rebuild the old pump or hopefully have you provide me with a solution.
Attached are pictures of the tractor ID plate, the hub and pump and a drawing of the required geometry of the pump/pulley. Tractor model looks like 37-1946 and serial # 134-729-721.
The water pump has 5 flat head screws attaching the back plate, with one screw small than the other 4. Pump has a casting # 190360
I have pics and a pretty good drawing of what I need - not sure if I can attach.
[/img]
[/img]
