andydap
hi, recently replaced a clutch and input transmission shaft on my oliver 1600. the hydraulics are a lot slower now than before so much so as to stop and lift the harrow at the end of the field and having to have it run at high rpms. also, I used to hear the pressure relief valve go off at both ends lifting and lowering, now I don't. it also used to leak hydraulic fluid to where I don't know and now it doesn't. fluid is new and the filter is new. any ideas?
andy
Assuming everything is the same as before, fluid level is full? Not leaking down? They leak into the rear end, usually through the pan or pump.
