oliver 1600
pinball
I am looking for a dual hyd port oliver tractor. guy has a 1600 gas model. he says it has 4 ports. anyone own or can tell me anything about how good or bad these tractors are. I suppose it has a 3pt, live power, etc. he is 5 hours from me so I need to know pros/cons about it. thanks for reading
I assume that you are talking about an Row Crop or Wheatland tractor.   The hydraulic "lid", the component that the seat is mounted on should have two ports on each side.   Those are outlet and return port depending upon which way the lever is moved.   If they have been used they will have a short pipe with swivels and a hose attached going to the rear for couplers.
5 hours is a long way for a tractor. If you said where it's located, someone might be close enough to inspect it in person for you and give some hooves feedback.
Donovan from Wisconsin
