880 Hydraulic Oil drain?
NYOlivers
I am going to change the hydraulic oil and filter on my 880. Can I drain the unit thru one of the hyd. couplers with the tractor running until the unit is empty? Like you can on a 4digit tractor.
You can also thread a pipe nipple on the left side that just extends a little past the platform once you have drained the unit and then unscrew the cap or plug on the end and drain it anytime after that. Questions?
