Cdolan1983
New User
White 2-70 hydraulics heating up , flow divider is making a nasty noise but stops when I keep turning the steering wheel. line going to flow divider seems to be chattering. Filters have been changed. Heat seems to be coming from the flow divider first.
I think your spool is stuck. Take the flow divider off and take it apart and wash it good and clean. Put a pressure gauge on the flowdivider and see what the pressure is. and report back to us.
the flow divider has been pressure tested and tore apart and cleaned. Two mechanics have looked at the tractor but no body knows the white hydraulic system good enough to pin point what is wrong. Is the spool the piece that u insert inside the spring ?
Is it possible the pressure is good and spool is stuck allowing oil to blow by ? Why would the line be chattering like its starving for oil ? We checked flow divider and pressure tested remotes. everything is a ok ...
