Cockshutt 50 diesel - BUDA engine oil pressure adjustment he
Friend here in Australia has a Cockshutt 50 with a Buda diesel engine - oil pressure is at 20 psi to start and then it drops off - I know this is a problem - just wondered if anyone knows how to adjust oil pressure to 30 psi
thanks
Three or four reasons for a reduction in pressure as temp rises. Could be any one, or any combination of the four.
1). Wrong oil.
2) Bearing/shaft wear leaking more oil as oil thins.
3) That PRV has a leaky seat, leaking more as oil thins.
4). Oil pump needs an overhaul as pumping capacity is reduced.
RAB
