Company Logo Shop Now
TractorLinks.com
Cockshutt 50 diesel - BUDA engine oil pressure adjustment he
Aussie Ken
05-12-2019 21:28:05
Friend here in Australia has a Cockshutt 50 with a Buda diesel engine - oil pressure is at 20 psi to start and then it drops off - I know this is a problem - just wondered if anyone knows how to adjust oil pressure to 30 psi thanks
oliver90owner
05-13-2019 12:05:10
 Re: Cockshutt 50 diesel - BUDA engine oil pressure adjustment he in reply to Aussie Ken, 05-12-2019 21:28:05
Three or four reasons for a reduction in pressure as temp rises. Could be any one, or any combination of the four.
1). Wrong oil.
2) Bearing/shaft wear leaking more oil as oil thins.
3) That PRV has a leaky seat, leaking more as oil thins.
4). Oil pump needs an overhaul as pumping capacity is reduced.
RAB
J. Schwiebert
05-13-2019 08:40:57
It will not maintain the 20 PSI adjusting that screw will not solve the problem. More questions?
Mike(NEOhio)
05-13-2019 05:26:29
Look for a large slotted set screw and locknut at the front on the left side of the block. Nut is about 1-116, right behind the cam gear housing.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
