RANDY DAUGHERTY
I have a Oliver 1650 and the pto shaft has developed a leak that will leave a small puddle every time I park it. I went to the local ago dealer picked up a pto shaft seal pretty standard I thought, upon inspection it was not quite as simple as I thought. I started researching on this forum and found the pto stub shaft had to be removed and there are 2 orings a seal and some type of plug that should be replaced. When I removed the pto shaft there is only 1 oring I can find and no seal and no plug? Are there different set-ups for this? Can anyone give me a picture of this plug i am missing? When the shaft was removed gear oil came out of the hole and after it drained I can see straight through to inside that axle housing there doesn"t look like anywhere that a plug would go? thank you in advance any help is appreciated
