Supper 55 550 oliver PTO
D F S.D.
was there some discussion about the pin in the PTO shaft shearing off and what causes it the pin toward the rear inside the transmission then the shaft inside PTO clutch will move forward and allow the fiber PTO disc to break up into pieces on this form?
If the PTO shaft on the implement is too long or the implement PTO shaft can not move freely (no lubrication) that will make it happen.
Happened to mine. Got it fixed just recently, just about done with everything else, but more important farm stuff has been put in front of it now
