Switching an 1850 from 34" rubber to 38" rubber
ljm
Has anyone switched 34' single bevel rear rims to 38" double bevel rims?
I would prefer to keep the original cast centers.
I never did any Oliver's when I was in the tire business. I did some Case, IHC, JD, AC's over those
years. Get the rims and make sure you get them mounted straight on the hubs. They can be a bear to get
straightened up after they have been tightened down crooked. Make SURE you recheck the wedges or clamps.
Tractors are a bear to get up off the ground and get the wheel back on after the wheel comes off. When
they come off, 99 times out of 100 the rims and wedges are worn too much to reuse.
