Hyd leak 1800 wheatland
Seal in the hydraulic pump or hole in the oil pan. Don't remember it they have internal draft control rod like the 1850 or not,but if they do,the seal on that could be bad too.
Pump seals are bad or there is a hole worn in the pan between the hydraulics and rear end. I did mine, pump went bad. Hydraulic stuff that has tocome off is very heavy almost needs second pare of hands too.
