My '63 550 industrial with the oliver loader and backhoe, needs a new front hydraulic pump drive hub. This is the hub that bolts to the front of the crankshaft and has a splined shaft that connects to the hydraulic pump with a two sprocket chain coupler. The rubber bushings are worn out of the original hub and none of the local shops have any idea where to get another one. Maybe someone out there has a source.
I saved this oliver from a field where he was sitting for 15 years rusting away and I'm trying to get him back into running condition. I sure can use all the help I can get. Thanks.
